Results 21 to 24 of 24
Thread: FFCP 2016 bed leveling question
12-17-2016, 11:26 AM #21
- Apr 2015
- Northern Ohio
- 198
Nope just you. I have no tolerance for ignorance.
You are so stupid you aer confusing leveling with traming. You are not trying to level anything. You are trying to adrust the buils pate to be parallel to the gantry.
Let me put it to you in a way you can understand. Engineering and science is the basis for everything mechanical that humans use. Education is what you're lacking and by spewing the trash that you do is mis-guiding others.
Wow you are an way off base. I do this stuff for a living. I have worked with rapid prototyping for over 20 years. I also many patents for my designs. My prints rarely fail and I actually use them for actual products not just prototyping.
I have helped bill both on and off the forum. Try posting non-hack information you wont get criticized. I would much rather be viewed as a nerd than an uneducated fool with a lot of meaningless mis-guided posts.
12-17-2016, 11:41 AM #22
- Apr 2015
- Northern Ohio
- 198
I don't post much of what I print because it is proprietary and property of the companies I am doing the work for but I think my printer is working just fine. My fiance teaches cardiac ultra sound and I do a lot of printing prop work for her college. This is just one example.
12-19-2016, 09:08 AM #23
Comparing 3 point leveling to an animal is a bad analogy. Yes four point build plate "support" is better, just like an animal does better on 4 legs, however 3 point leveling is much easier. 3 points makes a plane. That's why a 3 leg table will never rock, but a 4 legged table will always need adjusting every time it moves.
12-19-2016, 11:27 AM #24
- Apr 2015
- Northern Ohio
- 198
