Results 1 to 9 of 9
08-27-2016, 08:35 AM #1
- Aug 2016
HELP! Build plate backboard hitting extruder fan
Hello hello hi,
I'm having an issue during initial setup. When the axis are homing the build plate back board, when rising, hits the extruder fan, causing the motor to jitter and require switch off as it cannot surpass this point.
Seems very strange.
Any help with this would be greatly appreciated!
08-27-2016, 04:15 PM #2
- Jun 2016
- Oklahoma
- 904
08-28-2016, 08:18 AM #3
If its the FF Dreamer I had the same issue with the side fan bracket crashing the back board over the Z axis lead screw (the black perspex with Flash Forge and logo decal). Seemed to me it was just a decoration so I took it off and no problem since
09-17-2016, 01:05 PM #4
09-17-2016, 11:25 PM #5
As a note to why my Dreamer crashed the backboard, its to do with having changed the extruder bar out for the WMD adjustable version.
It has the extruders offset to the rear not the front, I just realised so not a problem with the Dreamer but the upgrade part.
http://store.wmdproducts.com/index.p...&product_id=62Last edited by 595; 09-17-2016 at 11:26 PM. Reason: grammer
09-18-2016, 09:10 AM #6
09-19-2016, 09:09 AM #7
Yep you are absolutely correct the bar doesn't make any difference I just pulled it all apart to to compare and check in fact I got it screwed up about the offset as its the same sorry, I guess I was comparing the original bar I pulled out back to front looking for the problem.
Your upgrade bar was well worth it hands down so not intended as a criticism and you did tell me it wasn't designed for the Dreamer, just the fact I never noticed the problem before the change, so as I said about the side fan crashing the Z axis perspex cover, I removed it to stop the issue. I'll watch for someone else to solve it.
09-19-2016, 04:46 PM #8
Ya not sure about the fan not fitting. I guess the distance between the xends might be a little less than the Creator pro??? I thought the Dreamers had the same fan unit.
09-19-2016, 05:05 PM #9
I haven't seen a creator pro in the flesh but the photos on the FF website look the same with that FF logo Z axis cover I would think they use the same fan if its the same extruder It only hit when homing so it might be a quirk with the Dreamer. I cant see it hurting running with that cover off. If it really needs to be there I suppose I could print an offset version.
Do bed magnets deteriorate.
