Thread: Some parts doesn't want to print
08-06-2016, 03:21 PM #1doriandu45Guest
Hi!
I found a 3d model of a rafale, and I want to print it but there is a problem: the cockpit and the noze doesn't want to print.
When I import the model on the FlashPrint software (I've got the FlashForge Finder 3d printer), the plane displays correctly like this:
But when I convert the file into Gcode, it looks like this:
I also tried with Slic3r, but I've got the same problem.
(Ok, I can't upload my file......) So here is my file: https://drive.google.com/file/d/0BwP...ew?usp=sharing
Where is the problem? From the file? My print settings? (I use the default print settings)
PS: Sorry for my bad English, I'm French
08-07-2016, 06:48 AM #2
- Dec 2015
- 12
Hey,
I checked the file. It had some 3D printing errors. I fixed it using https://makeprintable.com/. The size is different, so if you want to resize to the original size. You should be able to print it now. Here is the fixed file: https://drive.google.com/file/d/0B-7...ew?usp=sharing
Let me know if it works out.
08-07-2016, 06:56 AM #3doriandu45Guest
Yes! It works!
Thank you so much!
08-31-2016, 10:22 PM #4
Use netfab, makeprintable takes too long and they literally spam you to hell to use it, not sure why they are so pushy.
Netfab, free, fast and works better
https://netfabb.azurewebsites.net/Hex3D - 3D Printing and Design http://www.hex3d.com
