Thread: Issue when trying to print
11-21-2016, 10:54 PM #1
- Sep 2016
- 12
Hi,
I am trying to print any file, but everything I do, it is as if the home axes were offset. I have tried to reset the settings to default but it doesn't seem like anything is getting fixed. Does anyone know how to fix this issue?
It is a MakerBot Replication 2X
11-22-2016, 05:26 AM #2
oh right. check the endstop is:
1) still where it should be.
2) working.
That's most likely the problem, the carriage is either not clicking the x-axis endstop or the endstop is not working.
12-16-2016, 08:04 AM #3
- Mar 2016
- Düsseldorf
- 9
Hi,
I had the same problem.
https://www.youtube.com/watch?v=SvZV-lnRtj0
In my case the x-axis cable had a loose contact. It broke behind the metal pin.
I was soldering the cable and now it works again, but you can als order a replacement cable.
Cheers
Thomas
12-23-2016, 05:47 AM #4
- Mar 2015
- Slovenia, Europe
- 76
#fontseeker
you have broken end-stop switch. Replace it and this problem will be fixed.
