  1. #1
    Can 3D Printed Gears Measure Up?
    When it comes to hobbyist creations, gears are usually a part of the equation for many mechanical devices—from racecars to clocks, puzzles, and more. The question is, how do 3D printed gears hold up? And the answer is: it depends. While they may not ever be able to hold up in terms of strength to traditional metal gears, with the proper printer, materials, and know-how, you can make some amazing 3D printed gears that will blow everyone away, as well as offering durability and surprisingly high performance. Read more at 3DPrint.com: http://3dprint.com/125143/3d-printed-gears-pass-muster/
  2. #2
    Student
    Oct 2013
    Location
    Las Vegas
    I've been printing spur gears with Taulman Alloy 910. The resulting gears are incredibly strong and durable. They could easily be used for medium duty production mechanisms. If you're printing gears, I highly recommend it.
  3. #3
    Jul 2014
    how are you printing that stuff ?
    I found it almost impossible to use.
    And as far as the 'article' goes.
    No information on gears. The entire thing boils down to: 'you can make gears and if you make them right they'll probably work'.
    Talk about a 10 minute piece knocked off by someone with bugger all knowlege on the subject.
  4. #4
    Staff Engineer LambdaFF's Avatar
    Jan 2014
    Location
    France, Aix en Provence
    Quote Originally Posted by Brian_Krassenstein View Post
    Actually it's more like "NEVER". You can do plastic gears. Yes. They're dirt cheap. Yes. They may work in short-lived low effort, low speed applications. Yes.
    If you intend anything else... well, don't.
  5. #5
    Jul 2014
    again depends on the material and usage.
