02-25-2016, 09:14 AM #1
Circle and arc patterns in outer shells
Hello, I have a WASP Delta 2040 printer and in all my prints there are circles and arcs patterns emerging.
Here are some photos:
Link: https://drive.google.com/file/d/0B_j...ew?usp=sharing
In the photos above you can see the arcs.
In the photo above you can see the circle on the left side.
I saw that there are other users of this 3d printer that have the same problem but couldn’t find any information about this. If there is a troubleshooting guide about this please share it.
My printer is currently in service so I can't test anything but any info would be appreciated.
Thank you for reading.
Last edited by Horia; 02-25-2016 at 10:05 AM. Reason: added links for bigger pictures
02-25-2016, 09:53 AM #2
make the pics bigger.
What slicer do you use - could be something to do with that.
ALso this is 3d printing - not injection moulding - you will always see lines and the odd pattern. It's just what it is.
02-25-2016, 10:01 AM #3
Here are the large photos:
I was using Simplify3d for the perimeters and Cura for circle.
I know it's 3d printing but a Kossel (that is 1/5 of the price of the WASP) doesn't do that.
02-25-2016, 10:49 AM #4
I wonder if it could be signal-noise induced on power-supply or motherboard ?
Might try filtering circuits, using a UPS (battery power-supply) for AC,
and separating stepper-motor wires from each other and other DC wires.
If wires are bundled together, they can transfer pulses
02-25-2016, 10:56 AM #5
03-04-2016, 10:21 AM #6
Someone had this problem and still no solution
http://forums.reprap.org/read.php?178,509378Last edited by Horia; 03-05-2016 at 04:05 AM.
