Thread: 3D scanner
01-04-2016, 03:37 AM #1
- Jan 2016
3D scanner
rojection technique non contact frequency conversion fringeFull Body Scanner Model# EDR_BC105S Field of View 700mmRx2150mm(H) 28"rx86"(H) Single Surface Accuracy <0.1mm Average Sampling Point Distance 0.7mm Light Source White Light Output Format wrl obj stl Image Resolution 1.3 Mega Pixel Texture RGB 24 digits Photographying Time 3 seconds-5 seconds Data Registration Automatic Calibration 3D Fiducial Mark Weight 720KG Dimension 400mm(L)x500mm(W)x2100mm(H) Power 4800W Power Voltage 220AC Interface Recommended Computer Configuration i7/8G Ram/Win7_x64 O.S. 3-Second finishing scan of the full body in 5 directions, and only 45 seconds to finish the data registration.
Projector (1280*800 WXGA; DLP)
Light intensity ANSI 3500 LM
Texture 24bit RGB
The minimum uptake time was 3 Minutes (scanning per 360 degrees)
Environmental light intensity compensation adjustment
Point cloud average point spacing 0.5-1mm
Single scanning accuracy of less than 0.05mm
Depth of not less than 1200mm
Shooting range maximum 250mm * 250mm * 100mm * 100mm * 100mm 240mm/ minimum
Output format STL, WRL, PLY, OBJ and other formats
Automatic mosaic of data
A scan integrity of the normal situation of more than 90%
Calibration method encoding logo point stereo target
Equipment weight 18.9 kg
Equipment power 220AC/198W
Connection mode Ethernet (Gigabit Network) connection
Operating system Windows7 64 Bit
Website: http://studio.3dplus.cn/en/index.php
Skype:c1111212432@163.com
Email: cheny@esdisplay.cn
Any
06-21-2018, 07:54 AM #2
- Jun 2018
3D scanner
Hello3D scanner is a device that records image data color and light intensity and either directly captures depth data or interpolates it from multiple images of an object at different angles.The latest 3D scanning technologies utilize a camera that combines a laser depth sensor and visible spectrum sensor. Amazingly, this kind of setup is actually available today in retail products such as notebook pc's, tablets, and even smartphones.ISO 9001 Certification in Kuwait | ISO 9001 certification in Iraq
10-11-2018, 12:56 PM #3
- Oct 2017
- 2
sweet - and sweet again
11-01-2018, 05:23 PM #4
Ender 3 Neo - Jam Problem
