12-16-2015, 05:51 PM #1
- Nov 2015
- 21
What material to use for VESA tripod adapter?
I am needing a VESA tripod adapter, and I found one on thingiverse that might do the trick:
http://www.thingiverse.com/thing:667265
If I were to print this design, what material should I use? It will attach to a specialized tablet holder weighing about 3 lbs.
12-17-2015, 02:03 AM #2
Unless the thing heats above 40°C, pretty much anything goes as long as you ensure the proper fill and perimeters.
If it does heat above 50°C, try PET, nylon or ABS.
12-17-2015, 10:54 AM #3
12-17-2015, 03:04 PM #4
- Aug 2015
- 256
Hmmm... the layer orientation would make me worry about it splitting and dropping the monitor on the ground. I would probably modify this into a two part object, so I could rotate the block that attaches to the tripod rotate 90 degrees, and then glue it to base that attaches to the monitor.
