Thread: Relief Map Help
10-26-2015, 07:02 PM #1
- Oct 2015
Relief Map Help
Hi, I'm completely new to 3D printing and want to explore this technology as it may help my goal of creating relief maps. I want to create very detailed relief maps of local mountains so that hikers, climbers, back country skiers can see exactly what the terrain of a particular mountain is like before going on an expedition. All the existing products I've been able to find seem to have very low 'relief'... ie. 2-4 inches of depth. I'd like to see much greater exaggeration of elevation and an detailed map overlay on the model (vacuum thermoforming printed terrain sounds interesting). I imagine the footprint of the finished piece should be 2ft x 3ft minimum... possibly to lay flat under glass (not necessarily hung on a wall). The key is that it can be used for route planning, more than just something cool to look at.
Again, I know very little about 3D printing and the possibilities it provides in relation to the goal. Any information on the subject from those in the know is appreciated!
Cheers.
10-27-2015, 05:18 AM #2
Hi,
I have tried a site called maptostl or something like it (it was featured in this forum some time ago) and it worked so-so : there were just too many holes in the shape to make it readily usable. It required a lot of postprocessing to have a workable file and manipulating STLs is not my forte.
I have found another website that gave "maps" as pictures where the height was coded in greyscale : that way you can use a lithograph code to make a STL. Better but still not great if you want to keept scales precisely and so on.
Overall, not much that is done easily and you end up with a map without the north indication, without even a town name and having a scale is not exactly easy. So ... either a lot of work to be done on your part or a lot more automation / programming to do.
10-27-2015, 05:00 PM #3
- Oakland, CA
- 935
That would be large for 3D printing, but easy for CNC routing. There are already people offering relief maps like that for sale - here's one: http://precisionpeaks.com/we-scale-mountains/
The main trick is to translate from the USGS DEM format to STL or another more common file format that the CAM or slicer software can use.
Andrew Werby
Juxtamorph.com
Do bed magnets deteriorate.
