10-26-2015, 12:26 PM #1
- Oct 2015
- 3
less violent (shaky) head movement?
I have a QIDI printer which is reportedly similar to the FlashForge and the MakerBot Replicator 1 Dual.
I am new to 3D printing, but not to CNC.
I was wondering why the head movement is so violent?
My unit shakes quite a bit during the infill of the reference cube.
Would adding shock absorbers help?
Is there a reason for not taking advantage of acceleration and deceleration?
10-26-2015, 01:24 PM #2
Do you have acceleration enabled?
Using Rep G you can tune the acceleration also to help with the jerkyness. Other than that printing slower overall helps.
If you are using the default makerware speeds of 90mm/s print and 150mm/s travel then the machine will probably sound like it is going to explode. Those speeds are for the Rep 2 that has only one extruder and therefore has a much lighter print head.
11-01-2015, 10:37 AM #3
- Oct 2015
- 11
Do bed magnets deteriorate.
