Thread: trouble with leveling print bed
10-19-2015, 06:23 AM #1
- Oct 2015
- 12
Hello, I have just bought a ff creator pro and am having a difficult time to get the bed level exactly horizontal.
I go into utilities on the LCD Panel, click on level build plate, at which time the build plate and the extruders come very close to each other and then i use the paper sliding technique under the extruders so check the friction.
once this is done, i click "ok" and then when i start to print, i notice that only the location where the extuder and the build plate were touching is it level, but not level in the other locations...
so should i manually move the extruder around to all 4 corners of the build plate and do the paper sliding techinque at all 4 corners? will it harm the printer if i manually move this around?
should I use a digital leveler app on my iphone?
any help really appreciated....thanks guys!
10-19-2015, 06:55 AM #2so should i manually move the extruder around to all 4 corners of the build plate and do the paper sliding techinque at all 4 corners? will it harm the printer if i manually move this around?
The stepper motors are switched off so you can move everything around with no problems :-)
10-19-2015, 08:48 AM #3
Don't agonize over it. Get it as close as you can. May take a bit of practice but you'll get to a point where a single pass over each corner is all you'll need.
Bear in mind also that you will get a bit of sag in your X rods so getting it exactly 0.1mm across the entire bed is impossible. Like I say, as near as possible.
10-19-2015, 06:10 PM #4
- Aug 2015
- 256
You're supposed to move the extruder around the build plate and set the level on all corners. The first time you do this you'll probably have to do it a half dozen times or more to get the right combination of settings for the three adjustment wingnuts, afterwhich only small adjustments are needed every few prints or so.
