Results 1 to 10 of 15
Thread: Just ordered my CTC :D
10-02-2015, 01:03 PM #1
- 441
Let's see how this thing compares to my Flashforge creator pro. I (hopefully) am getting the non-USB+ version (I mailed the seller and he told me to mention it in the comments) which seemed to be the main issue with this printer. Best upgrades for it?
10-02-2015, 01:20 PM #2
The wire and filament Guide, that mounts on top of extruder assembly, is a 'must have' ,
or the thermocouple-wires will soon brake.
This one can be downloaded and printed from thingiverse.com:
(it works and fits great)
http://www.thingiverse.com/thing:340031
Click picture for larger view
Fan guards, on Extruder 40mm fans, are Good to have also.
Filament wants to flop into them very Often.Last edited by EagleSeven; 10-02-2015 at 01:56 PM.
10-02-2015, 01:34 PM #3
- 441
Cool beans will get that printed soon. My damn FF pro bed plate stopped heating the other night, so PLA it is until I get that fixed also. Or the CTC arrives! Seem's like a very solid printer for the price though.
10-02-2015, 01:42 PM #4
We also added stiffeners on bed-plate and adjusting-Knobs under bed-plate.
Those are not necessary, like the wire-guide is, but they improve it.
Stiffeners, knobs and fan-guards can be downloaded from thingiverse.
I have a fan blowing on X & Y stepper-motors, since they get very hot on long prints and I've read about them failing.
10-02-2015, 01:56 PM #5
- 441
Got a pic of those fans on the X/Y access? Curious how you set that up. I am going to order another 40mm fan for printing with PLA, do you know if the flashforge mount will fit this?
10-02-2015, 02:13 PM #6
Stepper-motor Fan is a 6" 110vac fan, that hangs outside of printer on a bracket that I made,
at right front corner of printer.
Fan points at about 45deg angle into printer so it will blow on both motors.
I tried using a 3rd extruder (nozzles) fan but really Don't see a need for it
and it really gets in the Way when working on extruder-assembly,
to clean nozzles, tubes, etc.
All filaments I've tried work well without that 3rd nozzle fan,
and I think stepper-motors Fan is moving enough air around nozzles.
I want nozzles and printed-objects to Stay at Set-temp, Not be cooled by a fan.
If it's too hot, just lower the Set-temp in slicer software.
Much better results that way .Last edited by EagleSeven; 10-02-2015 at 02:31 PM.
10-04-2015, 09:18 PM #7
Glad to know you already have your printer! Happy 3d printing! I can't wait to see your creations!
10-09-2015, 07:31 AM #8
- 441
So the printer just arrived last night. Got it all set up, seems to be working pretty good so far. I did have one crack in part of the frame from shipping. I will be emailing them about it, hopefully they will send me a replacement frame part. Eagle, I printed out the parts for that filament+wire guide, but I don't have those M6 push-in connectors yet, probably not for a week or so. I see what you mean by the wires just are basically flopped down. Still safe to run the printer for awhile until I get those push in connectors? Also the firmware its running is "The creator 1.0", now I use Sailfish on my Flashforge, should I be upgrading the firmware to Sailfish on this as well? Thanks!
10-09-2015, 03:55 PM #9
I'm not sure what you mean by "push in connectors".
That guide only needs the plastic guide tubes that came with the printer.
They push into the new printed guide, and are easily removable.
the movement of filament keeps tubes in the new guide.
You don't need or want the screw in type guide tube ends,
if that is what you are talking about.
Those just get in the way when loading and unloading filament.
(pushing & pulling filament in & out of extruders)
Those screw-end-fitting guides Look good but they really slow down the process of changing filament.
Or are you talking about something else ?Last edited by EagleSeven; 10-09-2015 at 04:05 PM.
10-12-2015, 12:51 AM #10
- 441
Yeah nevermind on that, I got it on there and am using it. Still working on getting a Z axis stabilizer and some rubber feet. The bed plate on this thing is pretty bowed when heated, quite annoying trying to do full bed things in ABS. I currently have a replacement heating bed for my Flashforge creator pro coming in the mail, so I want to take my old flashforge bed (it needs new heating wires soldered onto it with a new wire) and replace it on this CTC. This should be possible right? I believe my biggest issue is it will need a different bracket to use with the flashforge bed, because it is a 3 screw instead of a 4 screw leveling system.
Also I would like to get spring loaded extruders put on. I was wondering, I don't use my left extruder on my flashforge. I could probably swap it onto the CTC, but would it have to be on the left side? I'm thinking so.....
