Thread: No scanning Preview
09-03-2015, 08:05 AM #1
- Sep 2015
No scanning Preview
Hello
My Scanner arrieved last week and i install the Software 1.4.1 and all works correct.
But on next Day i can calibrate i can scan but there is no scan preview and also no Mesh file at the end !
I have an GTX 660 ti Graphic Card Windows 7 x64 with 16 Gb Ram,i check all Driver in the Proberty Manager 2x Shinig 3d Camera installed all ok.I can see the light scanning.
I installed soft 1.5 but before scan is complete the Programm crashed and also no preview.
Now im back in 1.4.1 and Need your help what can Ido now?
Thanks BertlLast edited by Bertl; 09-03-2015 at 08:14 AM.
09-03-2015, 08:20 AM #2
- Jul 2015
- 29
About 1.5
First, do you calibrate, before scan?
Second, do you press the power button of scanner on the back? What the scanner projects?
Usually, before you open the software, it should be the background of desktop.
after you open the software, it's white light. and when you press the button of scan, optical grating come.
And you should also check the setting of screen resolution.
May this will help you.
09-03-2015, 10:29 AM #3
- Sep 2015
Thank you Alfred
Yes I made all the step as you say and all Looks correct ,I have the Background of Desktop,the white light and then the optical grating,
The Resolution is correct 800x600,he scans then the turntable rotate and so on but no preview and no mesh file.
When i tested the Cameras in free scan mode left and right camera have a Picture.
Any Idea greets Bertl
Ps: I take another Graphic Card with the same resultsLast edited by Bertl; 09-03-2015 at 11:31 AM.
09-05-2015, 08:05 PM #4
- Jul 2015
- 29
If it's possible, I want to communicate with you personally with email or skype?
Can you?Last edited by Alfred_technical_support; 09-05-2015 at 08:32 PM.
09-06-2015, 09:05 AM #5
- Sep 2015
Sure with email no problem,I`m glad
Thank You Alfred
09-06-2015, 09:31 AM #6
- Jul 2015
- 29
Mine is alfred_yang@shining3d.com
Could you tell me yours?
09-06-2015, 10:26 AM #7
- Sep 2015
I send you an Mail r.dvorak@utanet.at
