Results 1,031 to 1,040 of 4110
04-18-2016, 12:41 PM #1031
What is this spring steel sheet that you are talking about? lol
04-18-2016, 12:53 PM #1032
- Jan 2016
- 81
With the Maghold system you have a solid aluminum block with magnets in it, then you have flexible spring steel sheets with kapton tape on one side and BuildTak on the other that attach magnetically so you can remove the entire build plate easily and then flex/bend it to remove the parts.
https://www.youtube.com/watch?v=rKw8oF99ZHk
https://www.youtube.com/watch?v=ltIJcxn8HWE
https://www.youtube.com/watch?v=OeeRTt04gQA
https://www.youtube.com/watch?v=MLk5SHJNRmk
https://www.youtube.com/watch?v=7ExgJZ1pI04
04-18-2016, 01:03 PM #1033
Ohhh, thought you were talking about a stock part of QIDI printer.
04-18-2016, 01:18 PM #1034
- Aug 2014
- 627
I dunno that Maghold is great and everything but when you bend anything there are stresses on it and eventually they will deform. Just doesn't seem all that great of an idea to me to bend anything to take parts off so I would just wait for the glass to cool but I have a low tolerance for having to replace things so YMMV.
04-18-2016, 02:00 PM #1035
- Jan 2016
- 81
Even if it does deform at some point (I have printed hundreds of things and they are all still perfectly flat) the magnets are spread across the entire plate and hold it down quite well. Also replacement plates are $12, so I think I can afford a new one (Also I already have three of them and swap them out after each print, and have one with white Buildtak when I am printing something dark in color)
04-18-2016, 02:01 PM #1036
- Apr 2016
- 12
Hey everyone, just ordered one of these a few days ago! How well does the machine handle printing directly off an SD card vs hooking it up directly to a computer?
04-18-2016, 02:18 PM #1037
- Aug 2014
- 627
That is why I said YMMV but for me I consider that wasted money if I have to buy something again no matter how many times I get to use it though if I could be guaranteed it stays 100% flat (no deformation whatsoever) and I could get at least 1k prints off of it at 12 dollars then I might go for it.
I love the magnet aspect but I love glass and once you get a nice, reflective, translucent, base (could be a top or a side even) I know I don't want to go back to anything else.
04-18-2016, 02:31 PM #1038
No reason to directly tether to a computer. SD Card is better to use in case the computer likes to sleep or otherwise try to ruin your 15+ hours worth of printing. lol Really the main technical reason to not print from computer is because the USB cable can be an antenna for interference to enter the Printers electronics and cause havoc. Only hook to computer to make firmware adjustments and upgrades.
04-18-2016, 02:33 PM #1039
04-18-2016, 03:59 PM #1040
- Jan 2016
- 81
I have absolutely NO problems with BuildTak. I have even used it to print ABS on my Fabrikator Mini without a heated bed. I have used Glass in the past, and still prefer my flexible plate with BuildTak any day. I can pull it off literally RIGHT after a print finishes, and within seconds it is cool to the touch and the part is off the bed and I am ready to print again (Although I usually use a different plate because I have several ready to go. )
