Results 2,011 to 2,020 of 4110
06-28-2016, 11:10 AM #2011
- Feb 2016
- 360
I have run a bit of Ninja and a bit of wax filament through em.
I did have a bit of issues with the ninja when I ran it, but not with the lower enclosure...it was prior to my putting hands on a low-pro feed gear. Still a decent print though, even though it was just some gaskets.
From what I read Filaflex is a tiny bit more stable (in terms of being fed through the machine) than Ninjaflex. I am unfamiliar with TPU.
06-28-2016, 11:25 AM #2012
- Aug 2014
- 627
TPU is sort of in the middle. Ninja is the daddy of the rubbery filament and if you want the most spring, and/or bounce, you go with it but with all of these filaments they will take the path of least resistance so if there is any gap wide enough for it to escape through it will and WHAM, BAM, JAM.
That extruder is on my liked list but honestly I don't think it is all that good because you need no gaps up to the feed gear nor after it and that is pretty darn hard to do with that style of mechanism.
I figure the largest gap allowed would be the radius of the filament and to be safer go half the radius so on 1.75mm filament no air gap should be larger than 0.875mm (I would say to be best no greater than half of that) then it shouldn't escape and jam on you.
06-28-2016, 01:01 PM #2013
- May 2016
- 6
Thanks Syd_Khaos, when i first got the printer a few months ago i did try find out whether i had a Mk8 or Mk10 but could not find anything definitive so incorrectly assumed i had the MK8, i'd seen those before but ruled them out.
I'll give them a print this weekend and see how they fair, i've still to order some flexible filament, looking for something simple to start with, maybe some semi flexible filament.
06-28-2016, 01:40 PM #2014
- Aug 2014
- 627
06-28-2016, 04:27 PM #2015
- Jun 2016
- Oklahoma
- 904
How do you insert a picture in a post? Doesn't seem to be working.
06-28-2016, 05:29 PM #2016
- May 2016
- Annapolis, MD
- 523
The only way I have found it to work is if the picture is stored somewhere else on the web and is externally referenced within your posted text. This BB's attachment system is messed up. If your image was stored on imjur.com for example, the text looks like this: [Zimg]http://i.imgur.com/j4YJj2p.jpg[/Zimg]
Just remove the two extra "Z" characters I put in to keep this example text string from embedding an image.
06-28-2016, 05:34 PM #2017
- Aug 2014
- 627
Yep, broken and I bet you it is on purpose as the system admin doesn't want the server's harddrive filled with the images.
06-28-2016, 05:39 PM #2018
- May 2016
- Annapolis, MD
- 523
Was wondering if there actually was a sysadmin...
06-28-2016, 06:06 PM #2019
- Aug 2014
- 627
06-28-2016, 07:35 PM #2020
- Jun 2016
- Oklahoma
- 904
Install questions. Did you guys install the provided software or go straight to Simplify 3d? What version of Python did you install for Win7 64Bit?
Do bed magnets deteriorate.
