Results 11 to 14 of 14
01-05-2016, 05:36 PM #11
- Jul 2015
I think the tallest part is about 3 1/4 inches, and the largest by area is the base, which is about 3" X 4 1/4". All the parts were designed to print without support material. The cylinder, valves and piston rod are designed to print vertically, all the rest will print horizontally. I have a 8" X 12" bed (Airwolf XL), so I can print the entire engine in one pass, but regardless of size, you should be able to print this. My son has a simple XYZ Jr and it will print on his machine.
01-06-2016, 02:24 AM #12
However you want to call it, this is a nice achievement. Too bad the unit system used is antiquated ;-)
01-08-2018, 12:15 PM #13
- Jan 2016
GSchulz,
Did you use acetone smoothing or did you sand/ file the parts to fit?
01-28-2018, 03:58 PM #14
- Jan 2018
https://2018grammys.net/
Grammy Awards
Grammys 2018
Grammy Awards 2018
Grammys
The Grammys
Grammy Winners
Grammy Nominations
Grammy Awards Live
Grammys 2018 Live
Grammy Awards 2018 Live
Grammys Live
The Grammys Live
Grammy Winners Live
Grammy Nominations Live
Grammy Awards Live Stream
Grammys 2018 Live Stream
Grammy Awards 2018 Live Stream
Grammys Live Stream
The Grammys Live Stream
Grammy Winners Live Stream
Grammy Nominations Live Stream
Watch Grammy Awards Live Online
Watch Grammys 2018 Live Online
Watch Grammy Awards 2018 Live Online
Watch Grammys Live Online
Watch The Grammys Live Online
Watch Grammy Winners Live Online
Watch Grammy Nominations Live Online
