Results 21 to 24 of 24
07-06-2015, 01:51 PM #21
Interesting results. Took the model from the second picture, and applied a rounded corner as you suggested.
Took a big step backwards. LOL. Interesting.
Edit:
Ok, jsut remembered what The OP jsut mentioned, Red does not mean bad.
In the original design red = 8.03 somethings (The unit is not specified).
In design 2, red = 5.4 somethings.
In the latest design, red = 2.6 somethings.
So yes, it looks like it took the stress, spread it out, and reduced it by a quarter.
It'd be really nice if I could mouse over the color scale bar at the bottom and have it say what the value is, as the scale is probably not linear.Last edited by Marm; 07-06-2015 at 01:59 PM.
07-06-2015, 02:05 PM #22
Cool !
Sharp angles are to be avoided, they concentrate the stress, basics of mechanical engineering, which I studied :-)
07-06-2015, 02:41 PM #23
- Jun 2015
- 8
Sorry, units are on the list of things to add. They are consistent with the geometry units you are using. So for stress:
mm --> MPa (mega Pascals)
cm --> Ba (barye)
m --> Pa (Pascals)
in --> psi (Pounds per sq. Inch)
ft --> lb/ft^2 (Pounds per sq. Foot)
All the deflection quantities in the results display are in the units of length used for the geometry.
The legend scale IS linear.
This is NOT a sales pitch, but our plug-in for Rhino has A LOT more capabilities... building the cloud solution to the same level of sophistication will take time.
07-06-2015, 05:18 PM #24
Ender 3 Neo - Jam Problem
