Thread: Skew by Bounding box
06-20-2015, 07:19 PM #1
- Jun 2015
Hi everyone
Hopefully someone can point me int he right direction.
I have an object I want to make fatter at one end
To help you understand image a egg, and take the bottom half of that egg and make it bigger, but the top half has to stay exactly as it is
It is possible to manipulate a file in this manner? Maybe to skew it using only four points in a bounding box??
And if so which program out there is most suitable?
I have used Blender, Tinkercad, Autodesk 123d, Meshmixer, Meshlab and Daz
But I just cant seem to get any of these programs to do what I want to do
Anyhelp would be most appreciated
Cheers
Julie
06-21-2015, 09:29 AM #2
Well.... In OpenScad I would make a 2 dimensional object and extrude it at different rates as I moved through the 3rd axis. And that extrusion (or offset) number can be the result of a function so you can make it do what ever you want.
06-21-2015, 06:03 PM #3
- Jun 2015
I already have the object that I want to tweak
Never mind, I guess it can't be done - so back to the drawing board
Thanks anyway
06-21-2015, 08:02 PM #4
- Mar 2015
- San Diego, CA
- 107
It can be done in Sketchup with the FredoScale plugin tools.
06-21-2015, 11:57 PM #5
- Jun 2015
I had a play in Sketchup, but it doesn't look like Sketchup can import STL or OBJ files. So I don't think I can get my file in there
06-22-2015, 07:17 AM #6
While you could easily cut your model in 2, keep the upper part and then redo the lower half, you will soon reach a limit of what you can do with an STL : it will be very difficult to create a seamless integration. What I mean is however hard you try, it will be close to impossible to do a mesh that will have the correct tangence at the seam (see picture below, I kept your eggcellent example).
It would be much better if you worked with a parametric (engineering) CAD software. Because a proper engineering software allows you that kind of modifications.
06-22-2015, 10:24 AM #7
- Mar 2015
- San Diego, CA
- 107
