Results 1 to 10 of 74
Thread: Free build plate!!!!
06-09-2015, 12:35 PM #1
- Jun 2015
- 34
hey guys. i am a developer of "Diamond Black Build Plates"
we specialise in warp free build plates for pla printing.
we are trying to expand our market by developing build plates for a wider range of 3d printers.
all you need to do is reply back with the printer model you have and the exact size of build plate required to fit your printer.
the build plate is 3mm thick and designed to sit on top of your existing plate.
small office binders will help on the larger builds.
here are links to our other build plates on ebay with youtube videos just to give you the idea
http://www.ebay.co.uk/itm/2217809348...84.m1555.l2649
http://www.ebay.co.uk/itm/2217853467...84.m1555.l2649
http://www.ebay.co.uk/itm/2217969885...84.m1555.l2649
all i need is the exact size that you think will fit good in millimeters of the build plate.
if i think that your printer is popular enough then i will send you a custom made plate for you to keep, in exchange for
honest feedback on this forum
a raft is advisable when printing on this plate but we have had success without.
we have had some success with abs using 10% infill and as long as the part is small.
other materials untested
diamond black build plate.jpgLast edited by diamond black; 06-09-2015 at 01:32 PM.
06-09-2015, 01:13 PM #2
- Burnley, UK
- 1,662
I've been trying to find one of these but at 1/5 what I paid for the printer it is way too much, I'll stick with polycarbonate until I land on one cheap
06-09-2015, 01:25 PM #3
- Jun 2015
- 34
well this one is free lol and usualy retails at only £20
06-09-2015, 02:16 PM #4
- Burnley, UK
- 1,662
Well it's a Wanhao Duplicator 3 and it is 230 X 150.
But do they work with a heated chamber? When I am printing I have a heated chamber that sits at between 50 and 70 c depending on what I am doing.
06-09-2015, 02:20 PM #5
Sure, I will bite. LulzBot Taz 5. I believe its build plate is 300mm x 300mm borosilicate with a PEI sheet but let me verify it tonight with a measure.
06-09-2015, 02:31 PM #6
- Jun 2015
- 34
well its untested in those conditions so im am very interested to see the results
06-09-2015, 02:46 PM #7
- Burnley, UK
- 1,662
The problem I have is not one of sticking, it is sticking too much. I do not suffer form warp at all ever but I break a lot of stuff getting it off the build plate. I currently use polycarbonate but have to replace it regularly, once it gets scratched you cannot get stuff off it.
06-09-2015, 02:48 PM #8
- 314
Flashforge Creator Pro, 225x145mm build plate. I've got glass on it now so it's already set up for a taller than stock build plate.
06-09-2015, 04:08 PM #9
- Jun 2015
- 34
i was hoping someone would have this 1.
as the machine is a lot like the makerbot replicator 2.
06-09-2015, 04:10 PM #10
- Jun 2015
- 34
when you finish your print, remove the whole bed and put into freezer for 30 minutes, that should shrink the print faster than the bed and therefore it should just pop right off on its own.
