05-29-2015, 02:11 AM #1
- May 2015
3D Printer Completed assembly Huxley Reprap
- 3D Printer Motherboard: melzi main chip 1284 p
- 3D Printer Stepper motor A4982 chip
- Output power: 24 v input AC110-220 - v
- Maximum build area: 140 x140x110mm
- Printer dimension: 260 x280x280mm
- Printing filament compatibility: ABS, PLA, 1.75 mm in diameter.
- Building surface: PCB heating bed.
- Nozzle diameter:0.4mm (Optional 0.5mm)
- LCD control panel and SD card reader (optional)
- Precision standard: 0.1 mm
- Resolution: 0.0125 mm
- Construction speed: 1800 mm/min
- Move speed: 1.2 mm/minute
- Deposition rate: 33 cm/hour
- Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All soldered electronics and built-in microSD card slot for stand-alone printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
- Client operating system: MAC/Linux/Windows.
- www.reprapmall.com
05-29-2015, 06:26 AM #2
