  1. #1
    Help with boolean difference
    Hi,Im trying to use half of the attached meshes to make an imprint on a surface (like a chocolate box). I struggle to get it to work though. Have tried Boolean Difference inh Meshmixer and Blender, but does only pruduce non working results.Thanks for your help!Martin
    Attached Files Attached Files
  2. #2
    Staff Engineer
    Jun 2014
    I selected the Queen component, then performed a plane cut and aligned the cutting plane to the monolith. On execution, I selected both components and performed Combine. The result is attached. There was one flag within Analysis>Inspector but selecting it for repair did not cause any apparent damage. Hope this helps.
  3. #3
    Staff Engineer
    Jun 2014
    Okay, that was WRONG. You're asking for the difference and I did a combine. Sheesh. I'll get back on it in the morning.
  4. #4
    Staff Engineer
    Jun 2014
    Now that I'm awake, I used Fusion 360 to import both meshes, used Mesh/Modify/Combine and created the attached file. It passes Meshmixer's Inspector.
    Hope this is what you wanted. If not, let me know where the misunderstanding lies.
