Results 1 to 7 of 7
Thread: Infill troubles
05-11-2015, 08:52 PM #1
- May 2015
- 3
Infill troubles
I am having trouble with my infill on my DIY Corexy printer and marlin software. All of the motor steps are calibrated. I am using 1.75mm PLA with a E3d v6 0.4 nozzle.
The picture is at
0.2mm layer height
15% fill density
line pattern
infill 40mm/s
solid infill 40mm/s
05-12-2015, 02:13 AM #2
The infill layers are not adhering to each other. I would say it is somewhat under extruding.
You say the motors are all calibrated, does this include the extruder motor ? What have you done to ensure that ?
To have a good adherence, there is a parameter that states how much the infill overlaps the outer shells. What value have you stated ?
The outer shell also seems problematic even though your speeds are low : solve the infill and we'll see if it's still there too.
05-12-2015, 05:10 AM #3
05-12-2015, 09:28 AM #4
- May 2015
- 3
Every motor is calibrated, including the extruder. I measured how much filament has passed through the cold end without the hot end attached. Should I re-calibrate with the hot end on?
05-12-2015, 09:29 AM #5
- May 2015
- 3
I'm using Slic3r with these prints.
05-12-2015, 10:55 AM #6
the outside of the box is clean - bit rough, but I;d expect it to be less square of the motors weren't right.
have you tried changing the type of infill ?
06-01-2015, 10:45 PM #7
- Jan 2015
- 62
I don't know if the setting in this page satisfies you:
http://www.geeetech.com/forum/viewto...p?f=24&t=16366
Do bed magnets deteriorate.
