Results 11 to 20 of 27
Thread: Help Required: Corner lift
01-21-2014, 08:46 PM #11
- new jersey
- 752
check out this electronics box i modeled. scroll to the right and goto the last picture. they are a little bigger than necessary but you get the idea.
http://www.thingiverse.com/thing:157239
01-22-2014, 06:30 AM #12
Here's an stl file for a mouse-eared plate. If you are going to use it, add this file to slic3r first, then add your object file and arrange your object file on the top of the mouse-eared plate. If your object is too big, then highlight the mouse-eared plate and use the Scale function to enlarge it until your object's footprint is smaller than the plate's footprint.
Old Man Emu
01-22-2014, 08:04 AM #13
I have some pieces here, but I can't find our camera right now. Will get to it when the camera thief comes in.
01-22-2014, 09:35 AM #14
01-22-2014, 06:02 PM #15
Thank you both!!
This is something I have never seen, I'm going to watch your vid's and try out OME's STL!
Does it cause a drop/droop when going from one corner/mouse to the next?
Looks like a small gap to the ground?
01-22-2014, 06:28 PM #16
No, the bottom is flush across the parts and the pads.
01-22-2014, 06:29 PM #17
01-22-2014, 08:29 PM #18
01-23-2014, 06:41 AM #19
The pads are primarily to give more anchor contact to the areas likely to lift during the build. You can add them where ever you like. We didn't have a need to put them in the center.
01-26-2014, 03:31 AM #20
How thick are the pads? I attached two components I wanted to print to a rectangular piece with oval corners. I made it 1mm thick. I still got corner lift. I've redesigned with a thickness of 0.4mm and will up the bed temp to115C.
OME
