Results 11 to 17 of 17
Thread: ABL Servo not responding
03-08-2015, 10:20 PM #11
- Nov 2014
- 522
Hmm... Getting kids to bed pastie.org or pastebin.com your config so one of us can double check things... Have you set your offset yet?
03-08-2015, 10:49 PM #12
- Nov 2014
- 61
Do you mean this line? #define Z_PROBE_OFFSET_FROM_EXTRUDER -4.34
Here is my configuration.h:
http://pastebin.com/pU8i5qB0
03-10-2015, 01:37 PM #13
- Nov 2014
- 61
Still cant get this Z height to move down to the bed.... Could this be an eeprom issue? Ive read that some people had to disable it to get their ABL working
03-10-2015, 01:44 PM #14
- Nov 2014
- 522
oh you still have eeprom enabled... yes.. disable it
03-10-2015, 02:26 PM #15
- Nov 2014
- 61
Ok I gave that a try and it worked but how would I adjust the esteps then?
03-10-2015, 02:33 PM #16
- Nov 2014
- 522
firmware or gcode
03-11-2015, 09:30 AM #17
The reason disabling the EEPROM is useful when trying to get Auto Bed Leveling going is because very often it is picking up a bogus Z_PROBE_OFFSET number from the EEPROM. Disabling the EEPROM makes that not happen.
You can re-enable the EEPROM and do a M502 (Revert to default settings) followed by a M500 (store settings to EEPROM). At that point things should behave the same and you can start over riding individual settings.
