Thread: Dremel
03-03-2015, 04:42 PM #1
- Mar 2015
- San Diego CA
- 60
Dremel
You read that right...Dremel. I picked up one of these through Home Depot and I have had good success. The printer has only been out for a few months so there isn't much of a following that I have found. Even there own website is lacking a knowledge base. So with that in mind, I wanted to share an issue I ran into.
Issue: system rebooting during file transfer through USB / SD card
Reason: file name contains more than 39 characters
When submitting a build to the printer, the system saves the file (again) and adds a date code. This date code pushed my file over 39 characters in length causing confusion and frustration. Using the same file and shortening the file name, the model printed without errors.
I want to thank the team at Dremel for helping me solve this and hopefully this helps someone down the road.
03-04-2015, 07:51 AM #2
- 314
For future reference, the dremel printer by all accounts is the same thing (or at least very similar) to the flashforge dreamer so you may look to that machine for any additional problems or questions.
03-04-2015, 09:16 AM #3
- Mar 2015
- San Diego CA
- 60
Thanks for the information. it will be a lot of help.....and possibly upgrades
