Thread: Layer Height Issues
02-28-2015, 06:01 PM #1
- Nov 2014
- 58
Layer Height Issues
hi guys , so after battling with so many issues my printer now is printing "Decent" but now im facing this layer gaps . it seems that layers have been " squeezed " to much . if i print lower than 3mm the problem seems to be worse .
im printing ABS and i have done several changes to my printer to make sure its not hardware related . also i have done several extruder calibration and test .
things i have done :
Replaced threaded rods
Replaced Extruder motor
Adjusted belt tension
Test different setting on Slic3r , Cura and S3D .
leveled the bed as good as i can using ABL topography.
so my question is . this layer gaps are common with ABS or im having Z axis issues? Skiping steps ?
at this point i really don't know what else to check . so any help will be appreciated .
heres some example including a temperature test that i did:
02-28-2015, 08:23 PM #2
- Jul 2014
- Eastern Colorado
- 536
I don't see what you mean by "layer gaps". If it's the banding seen on that fan duct, perhaps your layer height is not an even multiple of your steps per mm.
02-28-2015, 08:43 PM #3
02-28-2015, 09:53 PM #4
- Jul 2014
- Eastern Colorado
- 536
03-01-2015, 12:14 AM #5
- Nov 2014
- 58
im printing at 0.3mm = 75 steps
0.24mm = 60 steps
0.2mm = 50 steps
can layer width affects this ? i see that in s3d you can adjust your layer width. i read in other forums that this needs to be at leat 20% bigger than the nozzle diameter. so for a 0.40 nozzle should be set at least at 0.48 ?
03-01-2015, 12:37 AM #6
I am using S3D as well and have it the width set to auto, which it sets as 0.48. I normally print at 0.2mm layer heights, but sometimes do use 0.3mm.
