Results 11 to 20 of 21
02-03-2015, 03:58 PM #11
- Dec 2014
- Canada
- 498
Yes probe is retracted normall
When I run a job, probe is up
Starts to home.. X, Y are done and the carriage moves up Z, and then prob lowers and then Z lowers down until Z endstop is hit,
once Z enstop is engaged the 2nd time, Probe retracts immediately, bumping into the bed, and moving the entire gantry up a few mm,
then ABL sequence starts, goes to first positon, probe lowers again and starts taking measurements.. after the 9 readings.. during the last reading it retract up bumping endstop into the bed, shaking the carriage again vertically
and then it starts printing.
I will take a video to help explain the issue
02-04-2015, 08:05 PM #12
- Dec 2014
- Canada
- 498
this is my current ABL sequence
https://www.youtube.com/watch?v=V6QG_-9rOzc
02-04-2015, 08:39 PM #13
That is some very thick glass on your bed! What firmware are you running? Are you running Bdac's fork of the Marlin tree?
What values do you have for these lines in your Configuration.h file:
#define Z_RAISE_BEFORE_HOMING 9 // (in mm) Raise Z before homing (G28) for Probe Clearance.
#define Z_RAISE_BEFORE_PROBING 9 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
02-04-2015, 08:55 PM #14
- Dec 2014
- Canada
- 498
yes its 1/4" its nice and flat
#define Z_RAISE_BEFORE_HOMING 10 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 4000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 10
02-04-2015, 10:48 PM #15
What version of the firmware are you running?
02-05-2015, 09:46 AM #16
- Dec 2014
- Canada
- 498
I dont recall, but i started from a fresh copy. thats about 2 weeks old
02-05-2015, 05:58 PM #17
My suggestion would be to grab the Dacb fork of Marlin and use that. You will get the enhanced G29 and that takes care of this issue with the probe hitting the bed during retraction. You should be able to get it here: https://github.com/beckdac/Marlin
His fork is being used by a number of MakerFarm people here. I suspect you will just compile it and it will go. But if it doesn't there are going to be lots of people here that can help you with any issues.
02-05-2015, 06:01 PM #18
- Dec 2014
- Canada
- 498
this works for the Rambo?
looking at the dates, this seems older
02-05-2015, 06:23 PM #19
- Nov 2014
- 522
02-05-2015, 11:19 PM #20
- Dec 2014
- Canada
- 498
Do you know whats "further ahead" about the ABL compared to the regular marlin?
Ender 3 Neo - Jam Problem
