Thread: Gaps at Layer Change Location
01-30-2015, 12:51 PM #1
All,
I have printed some 20mm cubes and dimensionally they look great, however I am seeing small gaps at the location that a layer starts/stops.
If I set the layer change to happen in random locations it is all over the place, if I use the default value of changing in the same location, it ends up being a corner that looks "off".
I am using Slic3r for all of this and was thinking that it might be a setting dealing with retraction on layer change and have started experimenting with that. Does anybody have a suggestion on what else I might try?
Robert
01-30-2015, 01:12 PM #2
Well, I set it to no retraction on layer change and that didn't resolve the issue, the gaps still exist.
I will measure the thickness of my filament again as I could see this being a case of not enough material being extruded maybe?
Robert
05-20-2017, 01:38 PM #3
Were you able to solve the issue? I currently am dealing with similar gaps like you've mentioned while printing Benchy.
05-23-2017, 07:06 AM #4
- Jun 2016
- Oklahoma
- 904
See if coast or wipe is on and change it and see.
