Results 1 to 10 of 12
Thread: Brim Adhesion
01-20-2015, 08:18 AM #1
- Dec 2014
- Canada
- 498
Brim Adhesion
Having issues with my Brim sticking down to my glass printing with ABS
I prep my glass.. Soap & water, then Iso Alcohol, then ABS Juice x 3 coats and then some hair spray
120 bed temp
245 nozzle temp
bed is level
My Brim is all over the place.. not sticking well
01-20-2015, 08:35 AM #2
- Nov 2014
- 522
Make your offset a little closer to the bed.
01-20-2015, 09:50 AM #3
- Dec 2014
- Canada
- 498
yep that was it. i feel like ive checked and adjusted everything 100 times! lol thanks
01-20-2015, 09:56 AM #4
- Nov 2014
- 522
I dont even check anymore i adjust up or down a few 10ths once i get close initially. It seems like even with a feeler gauge its never quite right and needs a slight adjustment up or down after the fact.
01-20-2015, 10:45 AM #5
sniffle, what do you mean offset. Just looking for clarification so I know what you mean.
Last edited by usarmyaircav; 01-20-2015 at 10:45 AM. Reason: tried doing @sniffle, guess @ doesn't work. :)
01-20-2015, 11:55 AM #6
- Dec 2014
- Canada
- 498
Since im using ABL (Auto bed levelling) he is referring to the offset from the Servo Z endstop Prob and the Nozzle, need to adjust the value in the marlin firmware Configuration.h file to that after it auto levels the nozzle is the right height from the bed.
01-20-2015, 12:01 PM #7
01-20-2015, 12:08 PM #8
- Nov 2014
- 522
Yeah with ABL, once you get close using something like a feeler gauge you can then fine tune using slight firmware changes, in increments of tenths or even hundredths
more negative is closer to the bed, more positive is further away. basically instead of a micrometer you use the ABL servo and switch along with the firmware to make micro adjustments that once found don't change
01-20-2015, 02:31 PM #9
I usually just get the firmware z offset close and then make a final small adjustment with the Z offset option under the printer settings in Slic3r.
01-20-2015, 02:36 PM #10
- Dec 2014
- Canada
- 498
is there a way to set a Z offset in Simplify3d?
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
