I ordered a W-03 card but still couldn't get it to connect to my router at first.
I finally figured out the problem, my router was using wifi channel 12 but the flashair only uses channels 1-11 apparently ......
http://www.toshiba.co.jp/p-media/wwsite/flashair.htm
(see bottom of page)
So I switched the router to channel 11 and it's now working great !
Can now save directly to the card from S3D or access it from a mapped drive on the windows desktop.
@beerdart, I suspect this might be the issue you're having too.
Check which wifi channel your router is using and try changing it if it's above 11.
