Taulman 645 High-Strength 3D Printer Filament
Taulman 645
High Strength, Durable, and Non-Toxic
http://i0.wp.com/allabout3dprinting....size=300%2C239 Taulman 645 String Supporting 10lbs!
The Taulman 645
3D Printer Filament is made by the same company that produces
Taulman 618. 645 is a very high strength and durable
Nylon-based Filament. Like Taulman 618 it
excels at artistic projects as well. Taulman 645 is strongest when the
layer height of the filament matches the diameter measurement of your
Extruder Tip/Print Nozzle; a 1 to 1 (1:1) ratio. 645 is transparent by nature but can be colored using
dyes. Not only is 645 structurally strong, a large part of its durability is due to 645 having a very high resistance to degradation/break down from being exposed to chemicals, making it especially suitable for industrial environments. According to the creator, on
taulman3d.com;
“Greater resistance to chlorine, chlorides and bromides in addition to Alcohols, Resins+MEK, Oils, Acetone, Most all Alkaline, most 2 part Casting Compounds“.
