Results 11 to 20 of 29
Thread: ABL issue - long time away
09-07-2015, 05:53 PM #11
You can do a M502 followed by a M503 to print out what the bulk of your settings are. At worst case, that gives you a very very good head start towards modifying a new Configuration.h file so you can rebuild the firmware.
09-07-2015, 08:28 PM #12
- Jan 2015
- 445
Strangest thing.... I just finished a 31 hour print for a customer and when i went to start the next one, it worked fine.. What the what?
so i tested the macro a few times with the new numbers (from after i tried to fix it) and it was not where it needed to be... so i ran a print, and 10 spots ABL all same servo location, worked great. just as it always has...
so i avoided the headache for now, but i should probably get a good configuration.h stored somewhere haha
09-08-2015, 09:47 AM #13
- Jan 2015
- 445
09-08-2015, 10:20 AM #14
09-08-2015, 10:32 AM #15
- Jan 2015
- 445
its unreal... cant believe you are seeing the same thing
09-08-2015, 10:49 AM #16
And it isn't just the gears in the servo that cause problems. In some of the servo's there is a little potentiometer that provides feedback to the control electronics about how much the output is turned. If that potentiometer gets worn, it provides 'noisy' or inaccurate positioning information and things don't work right. You might want to try just swapping the servo and see if your problems go away.
09-08-2015, 11:02 AM #17
09-08-2015, 11:06 AM #18
09-08-2015, 11:39 AM #19
I agree with Roxy on trying another servo. Keep in mind that in 99% of the R/C servo applications, they are used in a closed-loop control system where minor positioning error won't matter - the control loop will just compensate for it until it sees the system (plane, helicopter, or whatever) responding as desired. Other than a servo issue, the only other possibility is a change in the zero-position pulse width being applied to the servo. There'd be no reason for that to change without firmware changes.
09-08-2015, 11:43 AM #20
- Jan 2015
- 445
Using a tower pro micro server 9g SG90
jsut happened to have a spare.. just wired it up. going to test now.
