Results 2,581 to 2,590 of 4110
07-29-2016, 12:06 PM #2581
07-29-2016, 12:46 PM #2582
- May 2016
- Annapolis, MD
- 523
07-29-2016, 01:03 PM #2583
- Mar 2016
- 52
07-29-2016, 01:07 PM #2584
- May 2016
- 31
Not really. If anything, I knock the whole thing off the QIDI since it's an open hinge design... but just once.
I've since managed to avoid doing that well enough. Version 2 of the hinge could just let the door separate at a specific angle, like 90 degrees. That would be a cool mod. That plus slide to keep open (could even bias the contacting faces of the notch so it prefers to "keep open", hopefully I'm explaining that well enough.) So many ideas, so little time...
07-29-2016, 06:51 PM #2585
- Jun 2016
- Oklahoma
- 904
Looking for a z axis shim, what are you guys using.
07-29-2016, 07:13 PM #2586
- May 2016
- Annapolis, MD
- 523
I like this one, but I have 8mm rods, so you may need a different version... It is around somewhere
http://www.thingiverse.com/thing:1427953
07-29-2016, 07:21 PM #2587
- Jun 2016
- Oklahoma
- 904
07-29-2016, 07:30 PM #2588
- May 2016
- Annapolis, MD
- 523
Failed? Print it with the indents facing upward?
I am using the Maghold build plate with a combination steel sheet and 1/4" boro stackup, so I've adjusted the thickness of the Zaxis shim to be a little bit thinner than the 6.35mm version. PS: I couldn't find a 10mm version.
07-29-2016, 07:32 PM #2589
07-29-2016, 07:38 PM #2590
- Jun 2016
- Oklahoma
- 904
I had the nozzle to close. Just did a cleaning.
I need to come up with a corner clip system for the glass.
Check out this shim, I just found it. http://www.thingiverse.com/thing:1670502
