01-16-2015, 12:19 AM #1
Fan which cools down the printer board?
Hi
I'm suspecting my fan on my printer control board to be running badly, makes alot noise. And I'm looking for a replacement, anyone know the specifications on it?
*I don't have access to my printer atm to measure myself, but is it 40 or 50 mm?
01-16-2015, 01:23 AM #2
- Dec 2014
small 24VDC fan sounds like a pig, just put 100Ohm resistor in series it will lower 24V down to 17V. Fan will lose some rpm and that squalling sound.
01-16-2015, 01:27 AM #3
40mm 24v. The stock one is very noisy. I am actually using a 12v fan on the 24v output and it is quieter than the stock fan even though it is probably running 2 times its rated speed. Some very knowledgeable electronics guys say that that fan isn't even needed because the mainboard doesn't get that hot. The fan actually just blows some air over the stepper drivers mainly.
http://www.digikey.com/product-detai...208-ND/2621113
This one will work if you want to try it. Not sure how loud it is though compared to the stock fan.
01-16-2015, 03:04 AM #4Hex3D - 3D Printing and Design http://www.hex3d.com
