Results 1 to 10 of 14
Thread: Largest item printed on i3v?
12-17-2014, 08:29 PM #1
- Dec 2014
- Canada
- 498
Im Curious what is the single largest object you folks have sucessfully printed on a i3v?
the 12" i3v has alot of room to print. but i havent seen any pics of anything really big
please post a pic or video if available.
12-17-2014, 11:07 PM #2
Understand that the 12-inch printer is very new. The first units have just been getting put together in the last week or so.
EDIT: These won't win any prizes, but my largest in the XY were the 8-inch supports at each end of my top-mount spool holder. Printed diagonally on the 8-inch print bed. My tallest Z was the 6-inch Z resonance test print from the Make: 2015 shoot out bench mark objects.Last edited by printbus; 12-18-2014 at 04:04 PM.
12-18-2014, 12:55 PM #3
- Dec 2014
- Canada
- 498
what about on 10" units?
12-18-2014, 02:56 PM #4
- Nov 2014
- 58
20141217_022149.jpgthis the biggest thing i have print so far. i have been having some power issues .
12-19-2014, 02:41 PM #5
Here is my largest print to date (today) on a 8'' bed of the rear mounted spool holder I'm working on. ABS 4mm brim/hairspray, no lifting.
12-26-2014, 06:11 PM #6
- Nov 2014
- Brevard, NC
- 182
8" pyramid base and 7.2" high on a i3v 10"
Here is a pyramid I designed in openscad & printed recently on my i3v 10". It has an 8" square base by 7.2" high & 1/4" round tubes. This was printed in PLA without fill with probably a brim of 4. The time from my log file was 5:20:40.
12-28-2014, 09:25 PM #7
- Nov 2014
- Orange, CA
- 78
the upper frame for my 15lbs combat robot (Low Blow)
on 12" i3v
print time 4hr 32mins
print settings
using slic3r
walls top and bottom are all 1.5mm thick and 20% infill
layer height at .35 .4mm hexagon using 1.75 Purple PLA Prototype-supply from Toy builders off amazon
print speeds are fast very fast
in / outside prem at 30mm/s internal shells at 120mm/s infill at 180mm rapids at 220mm/s
settings active in printer
jerk xy at 15 accel at 1100 Y Amax at 700 X Amax at 1100
this will be a lot more detailed later on building a Instructables Guide on the build when I'm done.
i will post a like in my build log and post copies of all the firmware i will make clones for the 8 and 10" on Ramps as well
01-01-2015, 05:32 PM #8
I realize you plan to put some info on instructables, but how about also adding a post to Marlin Motion Related Configuration.h Settings for MakerFarm i3v that explains how you arrived at these settings? I'm especially interested in the 180mm/sec for infill at a 0.35mm layer height. That seems like a lot of extrusion throughput.
01-05-2015, 05:46 AM #9
- Jul 2014
- Ontario, Canada
- 257
Thought I'd add my latest piece. Roughly 200mm x 200mm. Makerbot blue PLA, 0.3 in-fill, with speed around 75mm. Came out pretty well. For some reason the second layer printed higher than the 0.3 I had it set for, resulting in a weird band around the piece, but overall, pretty happy with it so far.
Ryan
01-05-2015, 07:54 AM #10
MiniMad-done on an 8" or a 10"? Nice looking part.
Do bed magnets deteriorate.
