Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Test print
  1. #1
    Student
    Nov 2014
    Location
    Ft Lauderdale, FL
    Add icanthinkofanid on Thingiverse
    Test print
    Have a look. I just finished this with my beta model.
  2. #2
    Student
    Nov 2014
    Location
    Ft Lauderdale, FL
  3. #3
    Technician Duck's Avatar
    Oct 2014
    Location
    Ontario, Canada
    What about something like this:
    http://www.thingiverse.com/thing:533472
    Or even just a 10 mm cube... and then measure the dimensions with a caliper?
  4. #4
    Oct 2014
    Location
    Ontario, Canada
    Maybe you need to calibrate very carefully the nozzle temperature:
    https://www.youtube.com/watch?v=FSOPsRiiOZk
    Look at how much difference just a few degrees can make
  5. #5
    Jul 2014
    So that's abs on a cold build platform - with what looks like gluestick glue on it ?
    Yeah the prints are a little rough, but abs ona cold build plate - that's very interesting.
    Or does the micro have a hot plate ?
  6. #6
    Oct 2014
    Location
    Ontario, Canada
    A great start when new to 3D printing is PLA. I recommend no raft, no supports, and PLA as the way to go until you get confident enough to move on. I have been 3D printing for 2 years and never use a raft. If you need more surface adhesion on a segment of your model just draw some 20 mm dia. pucks that are the same thickness as your first layer and trim them off with side cutters.
    I believe this user (Flyboy) has a printer with eccentric pulleys which is partly to blame for the quality.
  7. #7
    Oct 2014
    Location
    Ontario, Canada
    Any more progress flyboy?
  8. #8
    Student
    Nov 2014
    Location
    Ft Lauderdale, FL
    I just got my printer back from the guys at m3d. It's been completely upgraded with production parts. I'll get some more videos up soon. I'm waiting for them to fix a bug in the firmware(they are working over Xmas on the code).
  9. #9
    Oct 2014
    Location
    Ontario, Canada
    Great to hear! Troopers they are, for sure. Looking forward to your results.
    Can you take some close-up photos of the mechanical details? How rigid does the extruder feel? Is there a lot of flex if you grab the extruder and wiggle it?
  10. #10
    Student
    Nov 2014
    Location
    Ft Lauderdale, FL
    Hey,
    I'm still unable to make new videos at the moment. There is still some firmware glitches sadly.
    I may be able to do a short video of the mechanical details as it doesn't need to work for that.
