Results 1 to 10 of 16
Thread: Variable Capacitance Testing
09-21-2014, 08:30 PM #1
- Apr 2014
- 88
As per Rylan request, I have started this new thread to show my progress in testing Variable Capacitance as a viable means of real time Z axis feed back.
The variable Capacitor I used was made out of a length of 1/2" PVC pipe with a strip of Aluminium tape on the outside then wrapped with electrical tape to prevent shorting, the tape was then sealed with several layers of spray paint, the cathode is made up of 1/4" steel rod that has been covered with heat shrink tubing again to prvent shorting. the whole thing is held together by two custom made end caps made out of Poly-Styrene.
the experiment shown in the video consists of:
-6 Dixie cups with 50 ml of water
-3 of the cups had water that was left out for one and a half weeks to evaporate any Chlorine and to allow any disolved solids to settle
-the other 3 cups had water that was drawn straight from the tap just prior to the experiment only allowing enough time for it to reach room temperature
-each set of 3 cups had one cup refrigerated for an hour and a half, one cup that was microwaved for 40 seconds, and one that was kept at room temperature
-Each sample was tested for two minutes each (video has been sped up 2x to decrease video run time)
the purpose of this experiment was to show that simply making a variable capacitor will not make a reliable Z axis feedback system, however over the course of time I plan to build a sensor array that will allow the system to compensate for all the variables, making it 100% reliable
09-22-2014, 01:40 AM #2
- Burnley, UK
- 1,662
Why use capacitance when resistance will probably give you better, more repeatable and stable results?
If you use resistance and a Wheatstone bridge with one fully submerged for a reference and one that gets progressively covered as the depth increases then you have it sorted and stable. Capacitance will vary with location and even your proximity but resistance will not.
09-22-2014, 07:45 AM #3
- Apr 2014
- 88
09-22-2014, 01:34 PM #4
- Sep 2013
- 308
Aztecphoenix Thanks for taking the time to document this so well!!
Question, dose your cathode make electrical connection with the water ? or is it well insulated from the water via the heat shrink tubing?
09-22-2014, 07:57 PM #5
- Apr 2014
- 88
09-22-2014, 11:59 PM #6
- 19
I think you may be going about it the wrong way. The water itself should act as one electrode. I think a fairly usable capacitor could be made using a strip of copper foil, as one capacitor plate, along the inside wall of your build container, insulated from the water, perhaps with some kapton tape, or laquer, making sure to get a good seal around it. For the other "plate", place an electrode that won't corrode, close alongside it in direct electrical contact to the water all the way to the bottom. The water would be salinated, which of course it needs to be for the peachy anyway.
I don't beleive the salt level will matter much as you'd be relying on the capacitance, which is based on the thickness, and dielectric constant of what you use to insulate the strip. It should be unaffected by temperature, or resistance of the water. You could simply use this as the capacitor in a 555 timer based oscillator (astable multivibrator) if you keep it in the audio range you can read it on the mic input of a sound card. Sound cards are very good with frequency accuracy.
I could whip something up. I've been thinking about it a while, I've just been lazy and unmotivated :-P
09-22-2014, 09:28 AM #7
- Burnley, UK
- 1,662
I have no idea why you are wanting to do this as this is the first thing I have read but if I wanted to measure the level of liquid in a vessel one of the easier ways is to use an ultrasonic TX/RX above, pointing down.
09-24-2014, 08:05 PM #8
- May 2014
- hiding in your pillow
- 52
hmm- i wonder how this project gets away without liquid temperature sensors
09-28-2014, 06:14 PM #9
- Apr 2014
- 88
09-28-2014, 08:11 PM #10
- May 2014
- 52
It is, actually. the creator says as much in the comments page... anyway, it doesn't appear to be patented, so might be worth picking one up to see how it's gotten around the temperature problem (my bet is it has something to do with the dry+wet calibration it uses.
