Thread: Fualty sensor?
07-02-2014, 10:47 AM #1
- May 2014
- In a galaxy far far away.
Fualty sensor?
Printer: Printrbot Metal Simple. Using Repetier v 0.56
I think my sensor may be fualty/broken. When I try to home the Z axis, it doesn't home, it just goes up a little bit.
Do you know if the sensor is broken or if it may be a firmware problem?
07-02-2014, 05:37 PM #2
- 462
Your end stop may be disconnected or borked. Send M119 to the printer and see what you get back - it will tell you if the Z end stop is triggered.
07-02-2014, 05:42 PM #3
- May 2014
Ok. I will send that command and see what I get before getting a new part.
07-02-2014, 06:04 PM #4
And you can manually trigger your end-stops with your fingers to verify the status changes when ask the firmware to return their status.
