06-14-2014, 07:10 PM #1
- May 2014
- alameda calif
- 18
sailfish 7.6 and frimware failure
Hi guys
well after two days of mad printing I wanted to update to sailfish 7.6 as per the flashforge creator x manual
well now I cant print.
I took photos of my off sets but my extruder head just gos off the map and keeps going
when I fire up the printer it says "ff creator" it was saying "The Replicater" when I got it two days ago it read "The creator"
how do I center it to start a print? or reset it back
any help I would appreciate
06-16-2014, 01:49 AM #2
- May 2014
- alameda calif
- 18
thanks to dan I got it up and running
my ffcx is so much faster on sailfish 7.6 and cleaner
06-16-2014, 05:47 PM #3
What was the issue? I have been holding off switching to it, but was reading about the upgrade a little this weekend.
Faster and cleaner in what way? Do you have any part comparisons?
06-16-2014, 08:24 PM #4
Yea, so I was watching the lovethepirk videos and d/led replicatorg 0040r23-Sailfish. Should I look for something different. Sailfish 7.6
06-16-2014, 08:42 PM #5
- May 2014
- alameda calif
- 18
well I didn't follow the instructions and copy my off sets my bot would just run off to the end and keep trying to go
also I had some parameters off when I used the control panel some controls were reversed
I think I printed the 20mm cube in about 25 min with slicing on the stock firmware and the sailfish did it in 11min with slicing
the one on the left is sailfish
06-16-2014, 10:19 PM #6
- May 2014
- alameda calif
- 18
I have a flashforge creator x with 1280 chip... im a noob so get more info
I installed sailfish 7.6
dennis I think that's right replicatorg 0040r23-Sailfish gets you sailfish 7.6
after a day and a night trying to get back what was shipped I.E. in I was printing before the update....
and at times wish I didn't update...
im printing but I got 8 things out when I first got it and I'm sure ive burned out the kerpton tape
I was wiping with alcohol after every print . then I went to glue stick but I just tried one from the dollar store and it didn't work, then acetone and abs mixed but that didn't do it
so ya Im not sticking very good now
I was able to go back to the old firmware but it was not creator 1.0/ 7.2 it was just 7.2mighty board
keep notes take pictures of your setting
06-16-2014, 10:35 PM #7
- May 2014
- alameda calif
- 18
I got help from dan over at goggle groups flash forge
https://groups.google.com/forum/#!forum/flashforge
