10-23-2017, 04:32 PM #1
- Jan 2015
- 20
Stepper Clicking followed by offset layer
Randomly during a print I will hear a clicking sound and than discovery that my X axis has an offset layer. I tried swapping one of the extruder sterpper with the x server and I still have the same issue. What else would cause this?
10-23-2017, 08:55 PM #2
Too name a few.
Stepper Motor Current, Belt tension incorrect and slipping, X-Axis gear slipping, X-Axis Binding, debris blocking belt, Bad Bearings.
10-24-2017, 05:53 AM #3
10-25-2017, 07:55 PM #4
- Jan 2015
- 20
Whoops that might help. Its a Flashforge creator pro
What should the voltage be at the motor?
I think my tension is good
The setscrew on the belt pulley is tight
Would a bind be a consistent problem or could it happen at random? It seems like the guide rod mounts would have to be broken in order for the guide rods to not be parallel
Belt and pulley are clean
Which bearing?
Thanks
12-18-2017, 06:14 PM #5
- Aug 2015
- 256
Could be the x-axis stepper motor cord, they all go bad eventually.
