  1. #1
    Stepper Clicking followed by offset layer
    Randomly during a print I will hear a clicking sound and than discovery that my X axis has an offset layer. I tried swapping one of the extruder sterpper with the x server and I still have the same issue. What else would cause this?
  2. #2
    Jun 2017
    Location
    Washington State, USA
    Too name a few.
    Stepper Motor Current, Belt tension incorrect and slipping, X-Axis gear slipping, X-Axis Binding, debris blocking belt, Bad Bearings.
  3. #3
    Jul 2014
    what printer is it ?
  4. #4
    Quote Originally Posted by curious aardvark View Post
    Whoops that might help. Its a Flashforge creator pro
    Quote Originally Posted by Roberts_Clif View Post
    Too name a few.
    What should the voltage be at the motor?
    I think my tension is good
    The setscrew on the belt pulley is tight
    Would a bind be a consistent problem or could it happen at random? It seems like the guide rod mounts would have to be broken in order for the guide rods to not be parallel
    Belt and pulley are clean
    Which bearing?
    Thanks
  5. #5
    Engineer-in-Training
    Aug 2015
    Could be the x-axis stepper motor cord, they all go bad eventually.
Tags for this Thread
