Results 11 to 14 of 14
10-15-2017, 12:42 PM #11
- Jul 2017
- 193
Is that layer mode? Anyway, Cura 2.7 looks like this. Much better.
But still will need supports
10-15-2017, 01:40 PM #12
I have All Cura's Just use the 15.04.6
Also I noticed that in ideaMaker your model has 96 Non-Manifold Edges that need to be fixed.
When ready to print there will be a little green check-mark in the lower right hand window.
And I like the Fact that I can add Manually add supports.
https://www.youtube.com/watch?v=_2G5vahwA8w
Thank youLast edited by Roberts_Clif; 10-15-2017 at 04:23 PM.
10-16-2017, 04:03 AM #13
- Oct 2017
- Germany
- 7
Hello again,
actually I noticed that ideamaker (which I use, don't know how to set up Cura for my raise3d N2) is
damaging the model when using the repair function.
It seems to be that the STL-files created from SketchUp are somewhat crappy.
Really should try to get my feet wet in a better CAD-SW... But I do not like Fusion3D and
Blender confuses me even more...
The lower mounts came out quite well, yes.
Thanks for testing the strength of it - maybe I should make the tube a bit stronger;-)
I tried a print w. Raise3D-PLA @ 215°C, Standard-Profile from Raise3D (Standard - N2 - PLA).
Did not use supports - the way this prints I thought that would not be necessary..?
10-16-2017, 05:54 AM #14
Hello;
I found this Forum, If you follow the instructions you can Import profiles into Cura.
I imported these into Cura 2.6.2, this will give you the ability to use Cura with your Raise3D
raise3D_N2_dual
raise3D_N2_dual
raise3D_N2_plus_dual
http://forum.raise3d.com/viewtopic.php?t=1562Last edited by Roberts_Clif; 10-16-2017 at 06:14 AM.
