Thread: difficulty with ABS
08-20-2017, 05:45 PM #1
- Aug 2017
- 95
difficulty with ABS
Printer: Qidi X One V2. This unit has plexiglass side & front panels and hood.
I printed a relatively large item in Hatchbox PLA , temps: 40 Bed, 215 extruder. The part came out perfect. Then I tried the same piece in MatterHackers ABS pro, temps: 60 bed, 233 extruder but it warped and separated. 2nd attempt separated even earlier in the print. Both printed with rafts. See pic below... red is PLA, black ABS. Do I need to tweak the temps? Or is this just not gonna work in ABS?Last edited by raylo32; 08-20-2017 at 06:02 PM.
08-20-2017, 06:33 PM #2
- Aug 2017
- 95
Will do.... I just looked and realized I had not changed the material type to ABS in Simplify 3D. I am trying again, with bed=100 which is what it defaulted to in ABS mode.
08-20-2017, 07:10 PM #3
- Aug 2017
- 95
I am trying again with pretty much the S3D Qidi X One ABS defaults except I bumped the extruder temp to 230 from 225. Rookie mistake for me to forget to switch material types. We'll see how this goes and tweak from there. I am using 60% infill for strength, though that may be overkill for what I am using the part for.
08-21-2017, 05:05 AM #4
- Aug 2017
- 95
Success... the higher bed temp, and maybe some other more subtle factors in the ABS setting did the trick. I need a few more so I'll try the next one with a little lower infill, like 40% or so and no raft. Thanks, guys.
