07-26-2017, 12:44 PM #1
- Jul 2017
Printing 700 micron wide using Ultimaker 2 plus extended
Hello everyone,
I was trying to 3D print a cylinder which is 700 microns wide using Ultimaker 2 plus, but couldn't do it. Can anyone just tell me If they tried something similar before? if so did you make any changes in the setting of slic3r? it would be a great help if I could get any suggestions. TIA.
07-26-2017, 01:45 PM #2
you'll probably need to change to a nozzle with a smaller diameter. 0.2mm should work.
07-26-2017, 05:36 PM #3
700 microns = 0.7mm
If you are lucky and printed with a .15 High-Resolution Nozzle layer height of 0.06 - 0.08mm speed at 16-20mm-S you may print a .7mm cylinder.
Do bed magnets deteriorate.
