Thread: Advice to fix sides
07-13-2017, 09:46 AM #1
- Jul 2017
- 8
Advice to fix sides
I am trying to figure out how to fix the sides on this print. I have played with a lot of settings to get my first layer down and although this one has some small curlinig in the corner on subsequent prints I have gotten this worked out and got it to adhere properly however I still cannot get the sides worked out so they are more "smooth" any tips advice on what may be going on here would be great. I am just getting into printing and have read lots of articles and watched a lot of videos but still having a hard time with this one. Specs below on what I am using
Monoprice Maker Select 3d Printer
PLA Plus (1.75mm)
210 First layer
205 Rest of print
60C bed temp (glass)
Cura Slicer
100% Fan Speed
0.2mm layer height
100% Flow
This particular one was printed with skirt but I have since switched to brim to help with first layer adhesion which has solved the curling corner.
https://www.dropbox.com/s/rpler46dr3...e_02.jpeg?dl=0
https://www.dropbox.com/s/j8i5k9vkkh...e_01.jpeg?dl=0
Thanks in advance
07-13-2017, 12:07 PM #2
- Jul 2017
- 8
Thanks I will do that this evening and see what happens. I appreciate the advise
07-13-2017, 07:41 PM #3
- Jul 2017
- 8
From these prints it appears everything is printing fine? Or maybe I am being naive because of the size. But i have attached some pictures. This was run at a constant 210 with the settings requested/described above. Please let me know if I can provide better views of the print.
https://www.dropbox.com/s/qghsc23r1r...r_01.jpeg?dl=0
https://www.dropbox.com/s/9ezg6xddlb...r_02.jpeg?dl=0
https://www.dropbox.com/s/49rxhat3ku...r_03.jpeg?dl=0
Thanks
07-14-2017, 11:12 AM #4
fanwise.
first layer = 0%
2nd & 3rd layers = 50%
4th till finish = 100%
It just looks like standard warp to me. Also try the buildplate at 50c not 60.
