Thread: Nema 17 stepper motor?
04-28-2014, 04:07 AM #1
- Apr 2014
What's the difference between these two? There seems to be a huge price gap.
http://www.sainsmart.com/sainsmart-n...d-printer.html
http://www.ebay.com/itm/5PCS-Stepper...item417da2d263
04-28-2014, 09:17 AM #2
1. The sainsmart stepper has a 300mm lead screw attached. Lead screws are expensive, and you would not normally use them on a DIY printer. Everything on the sainsmart web page is expensive.
2. I'd expect to pay about $17 for a stepper motor, so with the extra items, that's is a good deal on ebay. There is usually nothing to go wrong with stepper motors. It is usually the arduino clones and RAMPS board that you will have trouble with.
Old Man Emu
04-29-2014, 04:21 AM #3
- Apr 2014
04-29-2014, 07:26 AM #4
To use the leadscrew, you would also have to buy a lot of other components. This might be OK if your building budget is getting around $5000, but if you are a hobbyist, or early experimenter, threaded rod can provide highly accurate motion.
The ebay package has all the gear you need to convert pulses to motion. I'd buy it if I was building a printer that used NEMA 17s. My next project will use NEMA 23s.
OME
