05-24-2017, 01:09 PM #1
- May 2017
Can I change the power adapter of a MakerSelect V2?
Hey Guys,
I just ordered a 120V MakerSelect V2 and my country is a 220V.
Do you guys know if the power adapter inside the control box (the one with the lcd) is replaceable?
Is it a separate AC to DC converter or is it part of the whole unit?
If it's a separate unit then what voltage and amps does this thing need?
If it's a single unit then what is the amperage/wattage that it draws? (as I will need a 110V to 220V converter).
Thanks alot,
Roy
05-31-2017, 07:16 AM #2
- May 2017
Someone posted this in the review section for the monoprice unit. He took apart his DOA unit and saw that there is a switch on the power supply that lets you select 120/220 and his was set on 220 which is why it would not work. You might try removing the case ans seeing if yours has the same.
05-31-2017, 10:15 AM #3
- May 2017
Thanks alot!
