05-15-2017, 08:08 PM #1
- May 2017
- 12
Looking at getting into 3D printing questions
I have a object I want to print I have freeCAD but I'm not 100% sure the total size of the object is but I'm sure the CTC 3D printer I'm looking at getting should be able to print it? I have a bunch of questions..
1. What type of Filament should I use PLA or ABS? It's primary use would be inside a car
2. What software do I use to print and how do I print from the files?
3. given this printer seems to be made on the outside of wood is it going to be durable enough?
If I can think of anything else I will ask
05-16-2017, 03:43 PM #2
- May 2017
- 12
Anyone?? I really want to make sure if any improvements can be made as well
05-23-2017, 02:27 PM #3
- Apr 2016
- 120
ABS will last longer, has a higher melting point and is easier to sand and shape post print.
There are plenty of free or paid for packages. I use Simply3D, which is quite expensive, but well supported and easy to use.
The plywood frame is robust and fairly rigid. There is a limit to accuracy and layer height, so don't expect miracles at this price!
3D printing is a skill and you will find there is a learning curve to getting the best out of the printer. Don't expect a perfect print the first time you hit the go button!
05-24-2017, 03:49 AM #4
pet-g will last longer than abs, has higher glass point and is much easier to use and doesn't stink while printing :-)
Personally I'd go for the monoprice rather than ctc.
Lot of quality control issues with ctc machines that you don't seem to get with the monoprice versions.
06-03-2017, 12:59 AM #5
- May 2017
- 12
I ended up getting the Anet A8 and I'm printing on PETG right now and it's a little harder to use then PLA as far as layer height and stuff like that.
06-07-2017, 05:59 AM #6
Actually with petg, I'd previously only used it for very small things. Currently trying to print larger items and just can't get a clean smooth print.
So, yeah it can be problematic.
Do bed magnets deteriorate.
