Thread: CUBE 3 Firmware HELP
04-10-2017, 10:44 PM #1
- Apr 2017
Hello All,
I have not touched my cube 3 for a while until recently. Now, whenever I attempt to print something it gives me an error code, telling me that the minimum version is not met. I'm pretty sure this is talking about the firmware of my printer, as I have not updated it for a long time.
When I tried to update the firmware, the printer could not connect to the server, and the USB always failed.
This is really bothering me and I would be immensely grateful if you could help,
Thank you.
04-10-2017, 11:14 PM #2
- Feb 2017
thank you!
04-10-2017, 11:34 PM #3
- Apr 2017
Are you experiencing the same issue?
04-14-2017, 11:14 AM #4
- Apr 2017
Some help here for what it's worth... First all the downloads are here: http://www.3dsystems.com/shop/support/cube/downloads
Second, (and you may have already done this) but don't bother with the USB stick that came with the cube, it's crap. Any USB will work. If you've tried that and it's the USB port, you're largely out of luck as 3DS doesn't provide components for the Cubes (they do for the CubePro... but I can't vouch for any cross compatibility of electronic components). That's said, it's a USB port and you may be able to source a replacement elsewhere.
That's about all the help I can offer at this point unfortunately. If you want to keep it running, there are people unloading them at VERY low cost online. May be good to keep an eye our for parts alone. Or... turn it into a planter and buy something else.
Good luck!
Do bed magnets deteriorate.
