Thread: Print problem
04-10-2017, 05:45 PM #1
- Apr 2017
Print problem
See attached picture. My Hictop printer has been printing great without issue, but recently started doing this. This is a 10x10x20mm test column. As you can see it is not smooth. Any ideas on what is causing this? I have y & x axis belts with no improvement.
04-11-2017, 01:30 AM #2
Can you post the picture again?
04-11-2017, 06:07 PM #3
- Apr 2017
I have tried. Does not seem to be working.
04-12-2017, 02:19 AM #4
Uploading a smaller picture usually works better.
It is likely to do with your flow and temperature settings.
But it can also be that a component of your print bed assembly or end stop mounts are loose.
04-12-2017, 03:23 AM #5
- Feb 2017
